HELP NEDED ASAP
tonci
HELP NEDED ASAP
Post by tonci »
Hi guys,
I need help asap...I can't comunicate with my megajolt with configurator v3.0.0 it does comunicate but it meses up tables every time I try to save them to controller. I had one version of cofigurator (I think v3.0.6 or something) that worked well but I've lost it together with my HD on laptop :( . The problem is that I have big drag race this weeken (state chamionship) and I need car tomorow. Please help. Is there a way to get hold of 4600's tuner software? Can someone PLEASE send it to me on my email (tonci.loncar at st.t-com.hr)
thanks in advance
Hi Tonci,
I would highly recommend upgrading to the 3.2.1 firmware and use the latest 3.2.1 configuration software.
** The 3.2.1 firmware fixed periodic corruption in the PC<-> MJLJ communications (while the engine is running) which can happen regardless of the software you are using.
** The firmware also significantly improves RPM stability. If you have a race car you really want this new firmware.
** The 3.2.1 configuration software improves communications through many fixes for USB->Serial adapters
Firmware upgrade guide here: http://www.autosportlabs.net/3.2.x/2.8. ... rade_guide
3.2.1 firmware here: http://www.autosportlabs.net/asl_dist/m ... V3.2.1.s19
Latest 3.2.1 software here: http://www.autosportlabs.net/MJLJ_Confi ... n_Software
tonci
Post by tonci »
I've tried to upgrade to v3.2.1, but it stops at this:''Waiting for HC08 reset ACK...'' so I presume that there is no bootloader on my motorola chip ( I did buy it programed from you about one year ago). I have tried upgrade from my old laptop that has serial port but it has windows 98 (can this be a problem?). How can I upgrade firmware if I don't have bootloader on motorola?
Edit: since when did you start to install bootloaders on motorola chips?
If you got the CPU pre-programmed, the bootloader is present- it would never go away. So you do have the bootloader installed.
sometimes the hc08sprg.exe is picky about USB->Serial adapters, but If your machine has a standard serial port it should work OK.
Are you following this sequence for writing the new firmware? Are you specifying the correct COM port?
(power down MJLJ)
> hc08sprg.exe COM1 mjlJunior_V3.2.1.s19
(now power up MJLJ)
..received 0xfc (good).
....programming sequence happens here...
tonci
Post by tonci »
Yes I have followed that procedure but it stoped at this:
can it be that it doesn't work with win 98?
I have not tested it on Win98, but it should work in theory. I use it primarily on Windows 2000.
Are you able to try a different computer?
tonci
Post by tonci »
Will try it tomorrow on my new laptop but with usb to serial converter...I am going to sleep now...it is 1.42 am here and I work tomorrow at 7 am :roll:
tonci
Post by tonci »
tonci wrote:Will try it tomorrow on my new laptop but with usb to serial converter...I am going to sleep now...it is 1.42 am here and I work tomorrow at 7 am :roll:
I managed to upgrade firmware with my new laptop...3.2.1 firmware working great now :lol: ...thanks
Excellent! I hope you did well at the races!
