Engine Mfg: Honda
Engine Code: ET2
Cylinders: 4
Displacement (cc): 1900cc
Rev Limit: 7.5k
TPS or MAP: MAP
Boosted or Normally Aspirated: NA
If Boosted- max Pressure (KPa): (at high altitude, highest KPa reads at 86kpa when the car is off
Modifications: Dual Weber 45DCOE, 285i/e w/12mm lift, 11.5:1 compression 4-1 Header with 2.25 collector. No Head mods
Chassis: AB1 (1986 Honda Prelude)
Notes: At high altitude (5300ft-10000ft above sea level)
1900cc honda motor...SOHC
well, here is the map i'm running right now, and its kicking ass, probably could use more advance up top, but here it is anyway!
- A20-DCOE-CB-07302011.mjlj
- A20 ITB ideal map adjusted for Altitude
- (786 Bytes) Downloaded 1230 times
