general ?
eeshaw
general ?
Post by eeshaw »
If there is a setup disc for the megajolt, does anyone know if there is a base line ignition map for it for the fuel injected chevrolet 350? Thanks
Moved to the ignition map forum. If you don't see something exactly, you could probably adapt an ignition map from a similar engine to start with.
