Lycoming map?
Genecockrell
Lycoming map?
Post by Genecockrell »
Has anyone posted or found a good map for a Lycoming aircraft engine? MAP will change significantly depending on altitude with RPM staying reasonably constant around 2500 RPM in cruise. Redline should be realtively low say 3000 RPM. Thanks in advance.
