installation help
Posted: Sun Feb 22, 2009 11:29 am
im in the process of wiring the rev limiter internally but im a bit confused with the installation guide.
i dont get these steps..
- Cut the REV_LIMIT trace on the MJLJ board running from the ULN2003 to the REV_LIMIT connector pin. The REV_LIMIT pin will now be the new COIL power supply..
- Connect the Rev limit COIL output to REV_LIMIT pin on MJLJ connector.
also, ive had to trim down the coil power and +12v wires quite severely to allow them to fit into the holes on the rev limit board. is this advised? the wires are more like 16/18 gauge for the last 3mm or so before the holes!
advice would be appreciated.
thanks.
thanks.
