Parts needecd
alainmengoli
Parts needecd
Post by alainmengoli »
ok so If I get it right I need the following: MJLJ fully assembled box (can't e bothered building one myself), EDIS from ford car (scrappy), crank posistoin sensor and wheel to adapt to crank (ford part). Anything else I am missing?
By the way it's going onto a Fiat 124 spider twin cam 2l engine (converted to carbs).
Josh_b
you need
Post by Josh_b »
a trigger wheel & a way to mount it, a crank sensor & a way to mount it, an edis module, a coilpack, some shielded twin core cable a soldering iron, some single core wire oh and some spare time,
alainmengoli
thanks for that just a quick
thanks for that just a quick one I thought the EDIS was part of the coil?
Paratime
Parting, blah blah blah
Post by Paratime »
No, the EDIS is a seperate part. The coils come in a pack, either 4 or 6.
alainmengoli
ok i get get it then 1 edis m
ok i get get it then 1 edis module and 1 edis coil pack
