Question: How Many Satellites does the GPS Typically Find?
Posted: Fri Oct 16, 2015 7:03 pm
by DavidNJ
I expect to convert to RaceCapture this winter. I'm currently using a 10Hz BT GPS receiver. With that receiver it typically shows 8-11 satellites where the smartphone shows 21-23 satellites. }
What is typical for the 50Hz GPS with the RaceCapture?
Posted: Mon Oct 19, 2015 6:15 pm
8-11 satellites is typical with the GPS receiver we have. However, note that these 8-11 satellites are the ones actually used for position; the cell phone may report more than that, but the signal quality may be too low to be included in positioning.
Note as well, the 50Hz mode requires perfect GPS conditions - line of sight from horizon to horizon, with minimal terrain and obstructions; such as seen on a wide plain or desert terrain.
Thanks for your interest!
Posted: Sun Nov 15, 2015 4:54 am
by DavidNJ
Are you planning a GPS upgrade that also uses GLONASS? My experience is GPS alone frequently has issues with a fairly weak signal from most of the satellites. With GLONASS in addition, the strongest satellites aren't any stronger, but the weaker satellites are a lot stronger.
What are the modes other than 50Hz? What is typically used?
Posted: Thu Nov 19, 2015 5:35 am
Hi David,
We're looking at glonass; requires a different GPS chipset as well as a dual band antenna. I'm curious if it will make an improvement in accuracy when used in challenging terrain.
But, it could be tempered by GLONASS being overall lower accuracy as GPS tech. Perhaps the chipsets can still leverage both to have overall better accuracy. We'll see!
