Micro SD Card size and data speed
SwedishKnievel
Post by SwedishKnievel »
If I want to log engine data (temps, pressures, RPM, AFR, MAP, etc) plus driver data (GPS, speed, brake pressure, steering angle) for an 8 hour endurance race how large of a micro SD card do I need? Assume I am capturing data at normal frequencies for the given sensor. For example, will something like this work?
https://www.amazon.com/SanDisk-Extreme- ... 9559992011
Please keep it under 32GB - RaceCapture/Pro is not compatible with SDHC cards. A fast card to reduce latency is helpful too.
8-32GB will be plenty for any endurance race.
Hope this helps!
SwedishKnievel
It does. Thank you.
Canyonfive
Post by Canyonfive »
brentp wrote:Please keep it under 32GB - RaceCapture/Pro is not compatible with SDHC cards. A fast card to reduce latency is helpful too.
Hope this helps!
didnt you mean sdXC is not compatible.
You are correct. SDXC is what's not supported.
