No power
BK
No power
Post by BK »
I've been using the MK3 for a while now with great success but I'm having an issue. No power when hooked up to the wiring harness. I've verified power exists to the harness and the ground is good. The unit does power up via USB to a laptop. Any thoughts? I'm at a NASA event currently and am missing my dash and data.
Below is the App Log(1.12.1), if that helps.
Brad
[RCPAPI ] trying last known device before each other device: COM5
[RCPAPI ] sendCommand exception caused by 'Port Closed'
[Traceback (most recent call last)]
File "autosportlabs\racecapture\api\rcpapi.py", line 436, in sendCommand
File "autosportlabs\comms\comms.py", line 173, in write_message
PortNotOpenException: caused by 'Port Closed'
[DataBusPump ] Checking for streaming API support
[StatusPump ] Already running
[TelemetryManager] on_data_connected: True
[TelemetryManager] start() telemetry_enabled: False cell_enabled: False
[TelemetryManager] self._should_connect is false, not connecting
[DataBusPump ] device supports streaming
[RCPAPI ] Message rx worker exception: u'{"status":{"system":{"model":"RaceCapture/Pro MK3","ver_major":2,"ver_minor":13,"ver_bugfix":5,"serial":"3E0048001651343034323934","git_info":"2.13.5","release_type":"official","uptime":32930},"GPS":{"init":1,"qual":0,"lat":0.0,"lon":0.0,"sats":0,"DOP":0},"cell":{"init":0,"IMEI":"","sig_str":0,"number":"","state}:"unknown"},"telemetry":{"status":0,"state":"idle","dur":0},"bt":{"init":1},"logging":{"status":0,"dur":0},"track":{"status":0,"valid":false,"trackId":0,"inLap":0,"armed":0},"imu":{"init":true},"wifi":{"active":true,"initialized":true,"ap":{"active":false},"client":{"active":true,"connected":false}}}}' | Expecting ':' delimiter: line 1 column 317 (char 316)
BK
Post by BK »
I've tested the MK3 directly to a battery via the pins on the unit with no success. It only Powers up via a USB plug. Please let me know if I need to send the unit back or other steps.
Brad
Hi Brad,
got your email - we'll follow up there. Thanks!
