Analog Outputs on RaceCapture Mk2
ZincBoy
Post by ZincBoy »
I have a RaceCapture Mk2 and am trying to use the analog outputs to drive gauges. When I configure the app to connect RPM to an analog out, the output goes to 5V and does not vary with RPM at all. The app shows the RPM varying as expected but nothing on the analog output.
I am missing something that needs to be configured?
Canyonfive
Re: Analog Outputs on RaceCapture Mk2
Post by Canyonfive »
post your script for what you are doing....
also what kind of signal is the gauge looking for?
ZincBoy
Post by ZincBoy »
No script, just using the RaceCapture GUI to select RPM as the analog output with appropriate scaling factors. Are the analog outputs only usable through the LUA scripts?
The gauge expects 0 to 5V corresponding to 0 to 6500RPM.
Hi, The channel configuration for the analog outputs only configure how it's locally logged in the log file; it does not "connect RPM to the Analog output".
You would use a Lua script to actually control the output, which is a more advanced topic. Information here:
https://wiki.autosportlabs.com/RaceCapt ... _Scripting
Hope this helps,
