Bosch Brake Pressure Sensor
notso2slo
Post by notso2slo »
So I am attempting to use a Bosch brake pressure sensor from a BMW DSC system, Bosch part 0265005303
I can't seem to get any variation in output, has anyone successfully used this sensor? I can get them for free, and they are easy to install in my current setup.
toga94m
Post by toga94m »
From http://www.bmw-planet.com/diagrams/rele ... /index.htm it looks like pin 2 is the output, front & rear signals are named DGR1 and DGR2. But the diagram doesn't show the power/common connections...
http://rb-aa.bosch.com/boaasocs/index.j ... rod_id=218
which shows 1=ground 2=output 3=+5V supply and you need a pullup resistor between the +5V and output..
So, how many of these do you have for free? :)
notso2slo
Post by notso2slo »
Lol, a few. I work at a wrecking yard which specializes in higher end cars. I'd offer to sell them cheap, but I can't guarantee if they work, and don't really have time to deal with "warranties"
madjak
Post by madjak »
I use the $30 ebay 1000PSI pressure sensors and they work very well.
