I'm Jonathan from Saint-Louis in Alsace (France).
I started to race motorcycle 3 years ago with a Triumph Street Triple, and have switch to a Kawasaki ZX6R now.
My old ST675 :
My new Zx6R :
I just bought a RaceCapture/Pro in order to improve my riding and settings. It looks really nice and is what I am looking for.
Hardware/sensors
I intend to plug the following sensors on my bike :
* GPS signal (included with Racecapture/Pro)
* Accelererometer / lean angle
* Throttle
* Brake pressure
* RPM
* Gear
* Front fork travel
* Rear shock travel
* Front tire temperature (left/right side)
* Rear tire temperature (left/right side)
* Wheel speed front
* Wheel speed rear
To what ends?
I want to achieve the following tasks with the datalogger :
1. Rider improvements (the biggest part !!)
* Reach better regularity
* Where I am not precise enough (brakes / acceleration)
* Where do I need to lean the bike more
2. Motorcycle improvement
* shock reaction and better settings
* Green light wenn tyre are in good temperature range
Questions
* Is it possible to plug a MCU on the board (RS232) to expand functionnality? What is the frame format required? Is it possible to plug more than one device (expansion + dash)?
* How to retrieve data? Is-it possible through Wifi/BT/USB, as I don't want to open the bike each time?
* Could I measure lean angle directly? Is calibration required (the datalogger may not be on a flat surface?
* How to start a record? Is there an input available? Can I use magnetic beacon with splits?
* Is it possible to add a time channel in seconds absolute (instead of hhmmss.000)?
* How is the logging configured? Through a LUA script?
I am looking forward to setting up everything and starting using the system
Thanks for doing this autosportlabs !!!
Best regards,
Jonathan.
Hi from France
Return to “RaceCapture/Pro introductions”
Jump to
- Autosport Labs
- ↳ General Discussion
- ↳ News and Announcements
- ↳ New Project Suggestions
- CAN Devices
- ↳ ShiftX2
- ↳ AnalogX
- RaceCapture App
- ↳ RaceCapture App Operation and General Q&A
- ↳ RaceCapture App Bug Reporting / Feature Requests
- CAN bus and OBDII integration
- ↳ CAN mapping discussion
- ↳ OBDII PIDs discussion
- RaceCapture/Pro | RaceCapture/Apex | PodiumConnect
- ↳ RaceCapture/Pro introductions
- ↳ RaceCapture/Pro General Q&A
- ↳ Sensors
- ↳ Hardware and Installation
- ↳ Lua Scripting
- ↳ Telemetry
- ↳ Bug Reporting
- ↳ Feature Requests
- RaceCapture/Track
- ↳ RaceCapture/Track Introductions
- ↳ RaceCapture/Track Operation
- ↳ RaceCapture/Track Installation
- ↳ RaceCapture/Track Bug Reporting / Feature Requests
- Megajolt/E and Megajolt Lite Jr. (MJLJ)
- ↳ Ignition Map Library
- ↳ Powered by Megajolt Gallery
- ↳ Assembly
- ↳ Installation
- ↳ Operation
- ↳ Q&A
- ↳ Future Upgrades
- ↳ Bug Reporting
- ↳ Fixes/Patches/Updates
- ↳ Hard Rev Limiter
