New RC Pro 3 user
Posted: Fri Oct 22, 2021 12:19 am
Good Evening:
I recently purchased a RC Pro 3 system to use in my 2002 Firebird racing in NASA's Camaro Mustang Challenge primarily in the midwest to the midsouth. I wanted to find a system that I call pull some engine data from the OBDII connection from my LS1 along with capturing track data. I hope to add TPMS system and possibly tire heat sensors. I used to run a traqmate system but it is no longer working. I am a bit overwhelmed by this system as it is way more complex than anything I'm used to. I am not a computer programmer, nor a mechanic, so a lot of the posts are way over my head. I'm already having trouble pulling data from the OBDII adapter. It was working for a bit but has stopped pulling RPM. Engine temperature is working as well as TPS, although appears to have a very chaotic signal. I'm hoping I can get this all working.
Robert
Robert
