coilpack order
Swedge
coilpack order
Post by Swedge »
my engine fires 1-3-4-2
do i connect up the leads like normal i.e. 1-1 2-2 3-3 4-4
or do they connect up
plug 1 to coilpack 1
plug 2 to colipack 4
plug 3 to coilpack 2
plug 4 to coilpack 3
toenee
Post by toenee »
Numbers on the coil pack are the order in which it fires, ie. number 1 first and four last.
So with a 1,3,4,2 firing order, number 1 lead goes to number 1 on the coil pack, number 3 lead goes to number 2 on the coil pack, no.4 to 3 and no.2 to 4.
Swedge
Post by Swedge »
yeah thats what i was thinking but there are different people saying different things on other websites
toenee
Post by toenee »
Shouldn't make a difference really, but I know mine seemed to run better with it that way around.
spandit
Post by spandit »
Am I right in thinking the coilpack fires twice (wasted spark) per revolution? I'm trying to establish whether mine is faulty
toenee
Post by toenee »
spandit wrote:Am I right in thinking the coilpack fires twice (wasted spark) per revolution? I'm trying to establish whether mine is faulty
Yep
spandit
Post by spandit »
Terrific...
Which pairs fire together?
toenee
Post by toenee »
1 & 4 then 2 & 3
spandit
Post by spandit »
Thanks. I've just ordered an infrared thermometer so hopefully it will tell me which cylinder isn't firing properly. By swapping the leads over, I can see if it's the coil pack that might be at fault
toenee
Post by toenee »
How close to the trigger wheel is the VR sensor, had a similar problem with a weak spark on 2 cylinders. Moved the sensor further away with 1 washer as a spacer (1mm) and that sorted it.
spandit
Post by spandit »
If I unplug the individual leads from the coilpack, the spark jumps about 2 inches - I think that's strong enough!
Not sure if misfire is happening at higher revs - at idle it's really lumpy with lots of popping from the hot exhaust (i.e. unburnt fuel - so don't think it's a fuelling problem).
I'm erring towards compression at the moment but want to know which cylinder is the bad one and every thing I can definitely eliminate will help
toenee
Post by toenee »
You get resister plugs in there ?
spandit
Post by spandit »
Yep, plugs seemed to be OK when I last pulled them a couple of days ago - none of them stood out as being covered in soot/oil etc. Why would resistive plugs make a difference?
toenee
Post by toenee »
Too little resistance in the circuit possibly ???
spandit
Post by spandit »
Why would that cause a misfire? Wouldn't that be a good thing? I've got resistive leads anyway so don't think that's the problem
