map sensor replacement
i have a mjlj and the map sensors gone faulty where can i either get a replacement or how do i go about wiring in a 3 wire 2 bar map sensor? any 1 done this?
Hi Chris,
How do you know the MAP sensor is faulty? Just want to make sure it's not something else.
The Map sensor is a Freescale part MPX4250AP - you could probably find it at Maplins in the UK, or you can purchase the MAP sensor conversion kit from us here (Assuming V4 controller)
http://www.autosportlabs.com/mjlj-conversion-p-50.html
Adding MPS
I have a TPS board, can i add this part to this board to have a MAP version. I have a Spitfire Mk IV so MAP is my preferred option.
- MegaJolt MOBO
- Webp.net-compress-image.jpg (232.54 KiB) Viewed 9482 times
