Coil and module power
speedfreek88
Post by speedfreek88 »
Just wanting to make sure I have this wired right... I have the coil power wire coming out of the MJLJ to the engine where it splits going to the EDIS module and the coil as it shows in the diagrams. With the rev limiter, it would cut power to both the module and coil... Is this correct?
Also when equipped with the MAP sensor version of the MJLJ do you just hook up a vac line to the port on the MJLJ?
stieg
Post by stieg »
Hey speedfreek88,
Have a look at the online instructions at http://www.autosportlabs.net/MJLJ_V4_ve ... tion_guide and hopefully they will answer your question.
You may need to change a setting in the MJLJ configuration software to instruct it to use MAP instead of TPS. But that shoudl be it.
Andrew Stiegmann (Stieg)
Principal Engineer
Autosport Labs Inc.
speedfreek88
I finally found the answer on here thanks!
