Need VR sensor connector
simonbos
Post by simonbos »
I am looking for the connector that connects to the VR sensor, (I was able to buy a new VR sensor..Standard part # PC_19). I have been unable to find one at the usual parts places and the weather here is not condusive to poking around in junk yards at the moment. Does anyone know where I could get a new one or does someone have one from a used car.
Cheers,
Simon
My question too. I'd like to
My question too. I'd like to know where we can get new versions of these connectors.
What about the ford dealership?
gt390dk
VR sensor
Post by gt390dk »
Hey there! Where did you find that VR-sensor? and price?
Jan
marty
CONNECTOR
Post by marty »
IF THE SENSOR I HAVE (WELLS#SU 264) IS CORRECT, THEN ANY BOSCH FUEL INJECTOR HARNESS SHOULD FIT.I HAVE SOME EXTRA ONES AVAILABLE. P.S. AM HAVING TROUBLE LOCATING THE 6 CYL. MODULE AND COIL PACK -ANYONE HAVE ANY?
jeffery_1965
Marty, I've seen quite a f
Post by jeffery_1965 »
Marty,
I've seen quite a few 6 pack coils on ebay recently, some starting around $10. I just picked up a quad coil for $5.99 plus shipping. Good luck!
Jeff
crank sensor connector
Hi, I'm in the market for a new sensor connector as well.. my connector was damaged when my crank sensor wheel broke off during a race this weekend.
The connector for the crank sensor doesn't look like any fuel injector connector I've seen. Where can you buy these?
Paratime
Getting connected
Post by Paratime »
I just talked to the Ford rep here, and he says that Ford doesn't sell the VR sensor pigtail separately. You can purchase the plastic portion of the pigtail with no metal pins, which are sold separately, thus requiring assembling the pigtail yourself. The plastic connector shell is part number:
F5RZ14489D
The coil connector is also not sold as a service part.
The VR sensor is available at most after-market parts stores. The Standard Ignition part is PC-19 for the 92-96 Escort 1.9
The module pigtail is available from Standard, part number S-744
Most Pull It parts yards sell a pigtail for 1 to 3 dollars. All I have visited have many, many EDIS Escorts.
Pantera
Source for VR Sensor Connector Pins
Post by Pantera »
Paratime, can you tell me where to get the pins that fit in the Ford F5RZ14489D VR Sensor plastic connector housing ? The part number would be a great help.
Paratime
On pins and needles
Post by Paratime »
I didn't get the part number for the pins, he just said they were sold seperately. The last time I bought pins, I took the part in with me when I picked up the connector shell. They had a big box of dozens of pin types, and the parts guy matched them up.
Pantera
VR Sensor Connector / Pigtail
Post by Pantera »
Paratime, I found a source for VR Sensor connectors complete with pins and about 8 inches of wire (what you would call a "pigtail"). It is made by Standard Motor Products and the part # is: S-812. It is available through Kragen, Schucks, etc. for $21.99.
beanbooger
Various EDIS components
Post by beanbooger »
Boost Engineering (see link in my signature) has used connectors with pigtails for coils, VR sensors, and Modules for $8 each, along with all other EDIS parts. Check the website out.
Brian
http://home.earthlink.net/~beanbooger/b ... gineering/
