2 stroke RPM and RCP crashing
rushy
Post by rushy »
I dont know if anybody else has had the same issue, but when connecting a wire from my HT lead to the Pulse Input every now and again the unit will crash and i will have to do a reboot.
I have some log files and the RPM is reading correctly, however it just is a bit hit and miss whether the unit will stay running for a period of time. The unit works perfectly if the pulse input is disconnected and the other channels log fine.
andylaurence
Post by andylaurence »
The inputs are only rated to 40V. I wouldn't hook a cable directly to the HT lead. You're probably frying the unit.
Sprinting an ADR Sport 2
www.endurancelay.co.uk
rushy
Post by rushy »
Anyone suggest what the best solution for this is?
andylaurence
I use an RPM output from my ECU. Do you have a similar output you could tap?
We are soon releasing a small adapter board called "CoilX" that will take the high voltage signal from a coil pack and convert it to a clean signal that RaceCapture/Pro can handle.
Information on the adapter can be found here: https://github.com/autosportlabs/coilx
We will be have built / assembled units in our online store within 2-3 weeks.
baz03
Post by baz03 »
With the karting loggers they clip on external sensor or some just a single wire back to the logger this is what Rushy means not directly wiring into the HT.
we do have access to the primary coil inputs that are voltage generated by mag rotor and stator type.
Any ideas what would be the best option to get a clean signal that RCP could handle?
Cheers Brian
ohiokm11
Post by ohiokm11 »
baz03 wrote:With the karting loggers they clip on external sensor or some just a single wire back to the logger this is what Rushy means not directly wiring into the HT.
Cheers Brian
In order to do the inductance route of acquiring RPM off the spark plug wire using a wire wrapped around it, the signal will need to be conditioned to a clean square wave in order for RCP to process it. There are some good visuals of what the raw signal looks like here: http://www.picoauto.com/tutorials/ignition-primary.html and here: http://www.dgp.toronto.edu/~mccrae/proj ... ignal.html
This is something that I haven't had the time to dedicate to getting sorted out yet, but if Brent has a solution coming soon, that seems to be the way to go :) [url]
ohiokm11
Post by ohiokm11 »
brentp wrote:We are soon releasing a small adapter board called "CoilX" that will take the high voltage signal from a coil pack and convert it to a clean signal that RaceCapture/Pro can handle.
Brent,
Any update on when we can expect CoilX to be available?
rdoherty
Post by rdoherty »
Ryan Doherty
Autosports Labs
ohiokm11
Post by ohiokm11 »
So its's $7 to ship a 1"x0.5" module?! I think $0.46 would be a bit more reasonable. Maybe even $2.
Hi Ohiokm11,
It ships out Priority Mail with tracking, and just like UPS, they have a minimum charge for shipping. Sorry for the inconvenience!
-Brent
