Can't disable predictive timing
Posted: Sat Oct 07, 2017 3:56 pm
by psfp
Hi guys,
For some reason, I can't disable predictive timing in my RCP Pro MK3. I turn it off on the app (windows, raspberry pi), write to the RCP, but it isn't disabled. If I read the data from RCP, it's back to on.
I tried to disable it directly on the txt (.rcp) file, by putting 0 in "sr" field under predTime, but didn't work either.
Posted: Sat Oct 28, 2017 2:36 pm
by psfp
Here is a quick video that I recorded to show the problem:
https://youtu.be/rFhdf8CDEu0
I'm not sure if this thread should be here or in app section.
Posted: Thu Nov 09, 2017 9:19 pm
Thanks, got it logged here:
https://github.com/autosportlabs/RaceCa ... issues/957
We'll see if we can get it into the next release.
Posted: Tue Jan 02, 2018 12:58 am
Should be fixed in the 2.13.0 firmware / 1.12.0 app release when it is available in beta later this week.
Posted: Thu Jan 18, 2018 9:47 pm
by psfp
Brent,
Looks like "predictive timing" was fixed, but now the problem happens to "race timing" option. It will show always "off", though.
Posted: Mon Jan 22, 2018 6:00 pm
Hi, can you clarify if you are using the beta 2.13.0 firmware and also the 1.13.0 app?
Posted: Mon Jan 22, 2018 6:20 pm
by psfp
Yes, I am.
Posted: Mon Jan 22, 2018 6:38 pm
We cannot re-produce a problem you described.
These combinations are valid:
Race Timing On / Predictive timing Off
Race Timing On / Predictive Timing On
Race Timing Off / Predictive Timing Off
Every time we tested this, we wrote the settings back to the unit and read the settings back, confirming the setting is retained.
If you still see this problem, can you post a video of it happening so we can see what is going on? when you test, be sure to write the setting before reading it again.
Posted: Mon Jan 22, 2018 10:03 pm
by psfp
Looks like the issue happens when "Predictive Timing" setting is changed. When "Race Timing" is "on" and "Predictive Timing" is changed from "off" to "on" or from "on" to "off", "Race Timing" is set to "off" as well:
I recorded a video:
https://youtu.be/_WAbjLwZe2w
Posted: Mon Jan 22, 2018 10:16 pm
thank you for that.
Are you seeing it happen on Android or Windows?
-Brent
Posted: Mon Jan 22, 2018 10:18 pm
by psfp
Windows and Raspbian. I didn't try to reproduce on Android.
Posted: Mon Jan 22, 2018 10:36 pm
We did see it reproduce once on RPi, not on windows or Linux. Very strange. We've logged the issue to inspect more.
If you do a read back and see race timing was incorrectly turned off, could you try shutting down the app and power-cycling, and then re-running the app with a fresh read? Would be curious if the setting was actually incorrect inside of RaceCapture, or if it was an app glitch.
Thanks!!
Posted: Tue Jan 23, 2018 8:20 pm
by psfp
Alright, if I shut down everything (app, RCP itself) and re-read the config in a new app section, after race timing incorrectly turned off, it will still appear as "off".
Posted: Tue Jan 23, 2018 9:30 pm
Thank you. That helps to know!
