Multiplexed ShiftX lights
paulbutcher
Post by paulbutcher »
This weekend I've been testing a script which multiplexes the ShiftX so that it operates as both shift lights and an error light.
If there's an error condition (temperature too high or oil pressure too low), only the central red light is illuminated. If there's no error condition, it operates as shift lights.
Here's the script:
Code: Select all
FREQUENCY_HZ = 10
RPM_THRESHOLDS = &#123;12000, 12300, 12500&#125;
MAX_OIL_TEMP = 100
MAX_WATER_TEMP = 100
MIN_OIL_PRESSURE_LOW_REVS = 5
MIN_OIL_PRESSURE_HIGH_REVS = 10
LOW_REVS = 3000
setTickRate&#40;FREQUENCY_HZ&#41;
function lightOn&#40;light, on&#41;
  if on then
    setPwmDutyCycle&#40;light, 0&#41;
  else
    setPwmDutyCycle&#40;light, 100&#41;
  end
end
function updateShiftLights&#40;&#41;
  local rpm = getTimerRpm&#40;0&#41;
  lightOn&#40;0, rpm > RPM_THRESHOLDS&#91;1&#93;&#41;
  lightOn&#40;1, rpm > RPM_THRESHOLDS&#91;2&#93;&#41;
  lightOn&#40;2, rpm > RPM_THRESHOLDS&#91;3&#93;&#41;
end
function oilTempError&#40;&#41;
  return getAnalog&#40;0&#41; > MAX_OIL_TEMP
end
function waterTempError&#40;&#41;
  return getAnalog&#40;1&#41; > MAX_WATER_TEMP
end
function oilPressureError&#40;&#41;
  local oilp = getAnalog&#40;2&#41;
  if getTimerRpm&#40;0&#41; < LOW_REVS then
    return oilp < MIN_OIL_PRESSURE_LOW_REVS
  else
    return oilp < MIN_OIL_PRESSURE_HIGH_REVS
  end
end
function errorCondition&#40;&#41;
  return oilTempError&#40;&#41; or waterTempError&#40;&#41; or oilPressureError&#40;&#41;
end
function displayError&#40;&#41;
  lightOn&#40;0, false&#41;
  lightOn&#40;1, false&#41;
  lightOn&#40;2, true&#41;
end
function onTick&#40;&#41;
  if getGpsSpeed&#40;&#41; > 10 then
    startLogging&#40;&#41;
  end
  if errorCondition&#40;&#41; then
  else
  end
end
paul.butcher->msgCount++
Silverstone, Brands Hatch, Donington Park...
Who says I have a one track mind?
http://www.paulbutcher.com/
Author of Seven Concurrency Models in Seven Weeks: When Threads Unravel
http://pragprog.com/book/pb7con
This is great. mind if we put it in the wiki?
paulbutcher
brentp wrote:This is great. mind if we put it in the wiki?
Of course not - feel free!
