Calculating Inverse Corner Radius
celer
Post by celer »
Hi, I've been trying to calculate the Inverse Corner Radius but I'm really not getting any results I expect:
Code: Select all
setTickRate&#40;20&#41;
icrId = addChannel&#40;"ICR",10,2&#41;
function onTick&#40;&#41;
  # Convert the GPS Speed to meters per second
  mps = &#40;&#40;getGpsSpeed&#40;&#41;*0.44704&#41;&#41;
 # Prevent a divide by zero
 if mps >=0.05 then
   icr = &#40;getImu&#40;1&#41;*9.806&#41;/&#40;mps*mps&#41;
 else
   icr=0.0
 end
 setChannel&#40;icrId,icr&#41;
 if getGpio&#40;0&#41; == 1 then
  startLogging&#40;&#41;
 else
  stopLogging&#40;&#41;
 end
end
What I get is either almost entirely all zero's or no readings. Any thoughts?[/code]
Hi, can you mock this out on your local computer feeding data to your formula? Also, some println() debugging statements would help quite a bit to see what it's calculating. Best is to build it up a little at a time and go from there.
