First Script - No Testing
[email protected]
Post by [email protected] »
Hi folks -
Due to some circumstances beyond my control, I've run out of time to test my first Lua script in the garage before I head to the track this weekend. I'd really appreciate it if you could have a look to see if there are any fatal flaws in the way I've assembled the individual scripts borrowed from this site.
Thanks in advance for any insights!
Cheers,
Bryan
Code: Select all
tickRate = 10
setTickRate&#40;tickRate&#41;
--FUEL LEVEL--
fuel2Id = addChannel&#40;"FuelLevel",10,2,0,8,"gal"&#41;
maxAvg = 100
fuelAvg=&#123;&#125;
fuel2Index = 1
function updateFuelAvg&#40;value&#41;
  local i
  if #fuelAvg == 0 then
    for i = 1, maxAvg do fuelAvg&#91;i&#93;=0 end
  end
  fuelAvg&#91;fuel2Index&#93; = value
  fuel2Index = fuel2Index + 1
  if fuel2Index > maxAvg then fuel2Index = 1 end
  local sum = 0
  for i = 1, #fuelAvg do
    sum = sum + fuelAvg&#91;i&#93;
  end
  setChannel&#40;fuel2Id, sum / maxAvg&#41;
end
--GEAR CALCULATION--
local _1stGear = 3.136
local _2ndGear = 1.888
local _3rdGear = 1.330
local _4thGear = 1.000
local _5thGear = 0.814
local FinalDrive = 4.30
local TireDia = 23.0
local gearErr = 0.1
local rpmSpeedRatio = 0
local gearPos = 0 --this is the gear channel variable
function calcGear&#40;&#41; --updates gear position every second by default
local speed = getGpsSpeed&#40;&#41;
local rpm = getTimerRpm&#40;0&#41;
gearId = addChannel&#40;"Gear",5&#41;
if speed > 10 then
   rpmSpeedRatio = &#40;rpm/speed&#41;/&#40;FinalDrive*1056/&#40;TireDia*3.14159&#41;&#41;
    if &#40;&#40;_1stGear - rpmSpeedRatio&#41;^2&#41; < &#40;gearErr^2&#41; then gearPos = 1 end
    if &#40;&#40;_2ndGear - rpmSpeedRatio&#41;^2&#41; < &#40;gearErr^2&#41; then gearPos = 2 end
    if &#40;&#40;_3rdGear - rpmSpeedRatio&#41;^2&#41; < &#40;gearErr^2&#41; then gearPos = 3 end
    if &#40;&#40;_4thGear - rpmSpeedRatio&#41;^2&#41; < &#40;gearErr^2&#41; then gearPos = 4 end
    if &#40;&#40;_5thGear - rpmSpeedRatio&#41;^2&#41; < &#40;gearErr^2&#41; then gearPos = 5 end
else gearPos = 0 end
setChannel&#40;gearId, gearPos&#41; --outputs to virtual channel
end
--START LOGGING--
function loggingStart&#40;&#41;
  if getGpsSpeed&#40;&#41; > 25 then
    startLogging&#40;&#41;
  end
--GOPRO CONTROL--
goproSsid = 'UnderbiteRacing'
goproPwd = 'Password'
goproStart = 30
--GoPro will be stopped based on IsLogging&#40;&#41; == 0 below.
--goproStop = 5
debug = 0
port = 4
wifiStatus = 0
lastInitTime = 0
initTimeout = 20000
function logMsg&#40;msg&#41;
  println&#40;'&#91;GoProWiFi&#93; ' ..msg&#41;
end
function sendCrlf&#40;&#41;
  writeCSer&#40;port, 13&#41;
  writeCSer&#40;port, 10&#41;
end
function sendRaw&#40;val&#41;
  for i=1, #val do
    local c = string.sub&#40;val, i, i&#41;
    writeCSer&#40;port, string.byte&#40;c&#41;&#41;
  end
end
function sendAt&#40;val&#41;
  if debug == 1 then logMsg&#40;'send&#58; ' ..val&#41; end
  sendCrlf&#40;&#41;
end
function toInt&#40;val&#41;
  return string.sub&#40;val, 1, -3&#41;
end
function httpGet&#40;url&#41;
  sendAt&#40;'AT+CIPSTART="TCP","10.5.5.9",80'&#41;
  sleep&#40;500&#41;
  local crlf = string.char&#40;13&#41; ..string.char&#40;10&#41;
  local get = 'GET ' ..url ..' HTTP/1.0' ..crlf ..crlf
  sendAt&#40;'AT+CIPSEND=' ..toInt&#40;#get&#41;&#41;
  sleep&#40;100&#41;
  sendRaw&#40;get&#41;
  sleep&#40;100&#41;
  sendAt&#40;"AT+CIPCLOSE"&#41;
end
function sendGoProShutter&#40;cmd&#41;
  httpGet&#40;'/bacpac/SH?t=' ..goproPwd ..'&p=%' ..cmd&#41;
end
function startGoPro&#40;&#41;
  logMsg&#40;'start GoPro'&#41;
  sendGoProShutter&#40;'01'&#41;
end
function stopGoPro&#40;&#41;
  logMsg&#40;'stop GoPro'&#41;
  sendGoProShutter&#40;'00'&#41;
end
recording = 0
function initWiFi&#40;&#41;
  logMsg&#40;'initializing'&#41;
  sendAt&#40;'AT+RST'&#41;
  sleep&#40;2000&#41;
  sendAt&#40;'AT+CWMODE_CUR=1'&#41;
  sleep&#40;1000&#41;
  sendAt&#40;'AT+CWJAP_CUR="' ..goproSsid ..'","' ..goproPwd ..'"'&#41;
  wifiStatus = 1
end
function processIncoming&#40;&#41;
  local line = readSer&#40;port, 100&#41;
  if line ~= '' and debug == 1 then print&#40;line&#41; end
  if string.match&#40;line, 'WIFI GOT IP'&#41; then
    wifiStatus = 2
  end
  if wifiStatus == 2 and string.match&#40;line, 'OK'&#41; then
    wifiStatus = 3
    logMsg&#40;'ready for GoPro'&#41;
  end
end
function checkGoPro&#40;&#41;
  if wifiStatus == 0 then
    initWiFi&#40;&#41;
    lastInitTime = getUptime&#40;&#41;
    return
  end
  if wifiStatus == 1 and getUptime&#40;&#41; > lastInitTime + initTimeout then
    logMsg&#40;'could not connect to GoPro'&#41;
    wifiStatus = 0
  end
  if wifiStatus ~= 3 then
    return
  end
  trigger1 = getGpsSpeed&#40;&#41;
  trigger2 = isLogging&#40;&#41;
  if recording == 0 and trigger1 > goproStart then
    recording = 1
  end
  if recording == 1 and trigger2 == 0 then
    stopGoPro&#40;&#41;
    recording = 0
  end
end
--MAX RPM FLAG--
maxRpmId = addChannel&#40;"MaxRPM", 10&#41;
maxRpm = 0
function logMaxRPM&#40;&#41;
  if rpm > maxRpm then
    maxRpm = rpm
    setChannel&#40;maxRpmId, maxRpm&#41;
  end
end
--MAIN SCRIPT--
function onTick&#40;&#41;
  updateFuelAvg&#40;getAnalog&#40;1&#41;&#41;
  calcGear&#40;&#41;
  logMaxRPM&#40;&#41;
end
First thing I checked was the use of a common onTick() function, which seemed to be there, so good job.
How is it working now for you?
[email protected]
Hi Brent -
Thanks for taking the time to reply. Due to some operator error, I didn't get the script saved on the RaceCapture unit before the last session. I did have success with the basic Amazon Fire tablet working fast enough to be a useful tachometer, and streaming telemetry to Podium from the Fire tablet over my iPhones personal hotspot.
Again, due to operator error, I didn't save any logs on the SD card. Since everything else worked automatically, I assumed the logging had also started.
I should have a chance to try loading the script in the shop before the next race at the end of January. I'll report back with my successes or failures...
Merry Christmas to you and the ASL team!
Cheers,
Bryan
No problem. Thanks, and keep us posted on the progress. :)
[email protected]
I had a chance today to test the script - no luck!
The script wouldn't load, giving me an "malformed number" error associated with the first line. When I remove the "--GENERAL--" comment, it would give me the same error associated with the "tickRate = 10" code.
When I copy and paste a basic script off the website, it will load fine.
Any suggestions?
Many thanks!
Bryan
When you look at the log after writing the script back to RCP, it will tell you what line number the error occurred.
You can also paste your script here if you get stuck.
[email protected]
Got it! To troubleshoot, I moved each of my functions into a separate script, but none would load. When they failed, I noticed that the error location was different in each, and eventually noticed that it corresponded to the first blank line.
In my copy & paste efforts, a number of "space" characters crept into the script, at empty lines and the beginning and end of other lines. Once I got those fixed, I had one missing "end" statement and now I'm up and running.
Thanks for the sounding board - I'm obviously still on the very steep part of the learning curve!
Cheers,
Bryan
