Virtual Channel help please
ross2004
Post by ross2004 »
I'm trying to create a virtual channel called "StintTime" to serve as a driver stint timer. I'm attempting to pull the getUptime() command to pull the time the unit has been powered up (divided by 60,000 to convert to minutes). This is my first time I've tried creating a Virtual Channel so naturally I'm screwing it up. Does anyone have an idea what the trouble may be? RCP3 on 2.14.0
timerId = addChannel(“StintTime”,1,0,0,250,”min”)
function drivetime()
local time = getUptime()/60000
setChannel(timerId, time)
end
setTickRate(30)
function onTick()
drivetime()
end
[lua] Startup script error: ([string "timerId = addChannel( 201cStintTime 201d,1,0,0,250, 201dmin 201..."]:1.0: malformed number near '201cStintTime')
[lua] Failure: Failed to load script
BigLobsterDude
Post by BigLobsterDude »
Check the double quote characters used around "Stint Time". I notice that that its different than than the quotes around "min". Might just be a posting anomaly, but I suspect your first quote character is not correct.
John
Schumacher Taxi #189
ross2004
Post by ross2004 »
Bravo sir! Thank you very much, somewhere along the way I assume copy/pasting back and forth from the Notes app the quotes got messed up. Now it's working perfectly. Thanks again!
Tip, you could connect a GPIO to reset the stint timer. You could do it in such a way that a button press resets the count to 0.
ross2004
Post by ross2004 »
True, but we power cycle the RCP at every pit stop, so that will serve us.
