Is there an alternate way to copy log files from the SD Card on the RCApex.
I know I can pull the SD Card and copy them off.
Is there a way to copy them via Bluetooth or WIFI?
Dennis
Retrieving Log Files from SD Card
I haven't used it yet but I was told recently that you can save logged data on remote tablest/phones if they are connected (bluetooth/wifi) during the datalogging and running the RaceCapture app. So if you're using a phone/tablet as a display it can automatically save the data to that same device. This is an option in Preferences I believe that should be automatically enabled though on my devices I found that wasn't the case.
Other than that I don't know of anyway to have a remote copy of data without pulling the SD card.
This does work, nothing to enable i dont think, you have to be on a dashboard screen for the logging to happen. Relies on the phone/tablet to do the logging. I tried it and works ok on shorter logs. The app locked up on me when I let it run on a longer trip, not sure if it was due to logging or not. Installed a micro sdhc extension to be able to access the sd card without having to dismantle my car... works nice.
