Weird thing started happening on my rct2 with podium. I no longer get lap times pushed to it or shown on the tablet. However all other telemetry is being pushed including GPS location. Any ideas? Only change I can think of that I made is upgrading app and firmware to latest.
Event: https://podium.live/events/1281dbf6-54f ... 759d98dfe5
Not getting lap times into podium
Hi Pete,
Thanks for posting. There might be something askew with the configuration. Can you send us a copy of your raceCapture configuration plus a zipped up copy of the log file from the session off of your app? You should have it under the Analysis view.
Please send it to [email protected].
Hi Pete,
Spotted your problem.
In your Setup you have "Race Timing" turned off. Try turning it on, under Setup / Race Timing, then write the settings back to RaceCapture.
Let us know if that works for you. Before your next event, you should be able to create a simulated track in a parking lot or road and test the lap timing that way.
Thanks Brent, that definitely did the trick. I suppose the setting may have flipped during the firmware upgrade and reloading config just never set it back. Either way, i'm good to go now. Thanks!brentp wrote:Hi Pete,
