Where are "Saved Sessions" saved?
GTIspirit
Post by GTIspirit »
I've got a "Saved Session" which I logged using the RaceCapture App 1.16.2 on my Windows tablet. This was logged from the RC Track Mk2, which doesn't have an option for logging per se. I want to move a particular saved session over to a real computer for analysis. Where are the "Saved Sessions" saved so I can copy the file?
Re: Where are "Saved Sessions" saved?
When you export a session, you can browse for the location where you want the file saved. On an Android device, you can typically browse to the DCIM folder (for example) - then, when you connect your android device via USB, you should be able to browse for files there.
For a windows device, you should be able to just browse wherever you want for the exported file.
Hope this helps!
