So it would be like this?
I assume the RJ45 CAN bus connection pictured above is from perspective looking into the device side female receptacle?
So the pin numbering to color convention is:
RJ45 Power, ground and CAN bus connections to RaceCapture/Pro EIA-T568B RJ45 cable color codes (check printing on the cable to confirm) Connection RaceCapture/Track MK2 (RJ45 cable)
Pin 8 +12v Brown
Pin 1 Ground Orange/White
Pin 2 CAN 1 High Orange
Pin 3 CAN 1 Low Green/White
Pin 4 CAN 2 High Blue
Pin 5 CAN 2 Low Blue/White
