Could not write configuration. Caused by: 'Port Closed'
fmbo
Post by fmbo »
Hi everyone,
I've tried to disable the custom race tracks and add sectors manually.
However, the configuration wasn't correctly flashed into the device. And after it I constantly get the following message: http://prntscr.com/j5hrk4. While trying to connect to ANY device.
Do you have any ideas?
A few questions so we can clarify help:
* What hardware are you using, and what firmware is it running?
* What version of the app are you running, and what OS or device? USB, WiFi or Bluetooth connection?
Are you able to read / write configuration otherwise and do you see data on the dashboard?
