Writing a map...
Edwardatherton
Writing a map...
Post by Edwardatherton »
Even though I have data on RPM/vacuum advance settings, is it better to...
1)run the engine at a certain speed then advance the ignition till the I find the highest revs.
2)Repeat the above for different RPMs.
or not?
Land Rover 1957 S1 88" 2.5 petrol/LPG
MartinM
Post by MartinM »
That might be a rather simplistic way if you only had 2D control, but when you say "run the engine", I assume you mean in the garage, so you will not be seeing any realistic load settings that equate to
- foot in the carpet at low rpm, i.e. lower rpm, higher kPa
- foot off the throttle at high rpm, i.e higher rpm, lower kPa
...because you won't be able to reproduce them.
If getting a map was that easy, all the rolling road tuners would be out of business!
You've got at least three options:
- do the above, note which cells you are covering and work out the best values for the other cells using the general features of all maps ie more rpm = more advance, more vacuum (lower kPa) = more advance, and any specific features you can find about your engine (max advance, idling advance, amount of vacuum advance at different rpms etc etc)
- keep increasing the advance everywhere and drive around listening for knocking; back off the advance where the knocking occurs - this is undoubtedly an option, but I would never recommend it - it could wreck valves an/or pistons 8)
- get it done properly on a RR
Martin
