PROBLEM SOLVED (see 3rd post in this thread)
I've been running a MegaJolt v3 on my 1380cc Mini for the past few year. Been a dream... until this morning's drive to work. It performance was lifeless... felt like limp home mode to me
Over lunch I hooked up my laptop/configurator to the MJ. The map is still present, but when I fired her up I see that the actual timing advance figure (bottom right 'gauge') does not track the actual advance described in the map table... instead it is bouncing in the 5 to 7 degrees range.
Hmmm.
Is this the sign of a fried MJ, or more likely that I need to chase down a wiring issue?
Any thoughts/advice would be greatly appreciated.
Cheers,
Colin.
PROBLEM... Is this limp home mode???
- advance not matching/tracking map table
- mj_issue.jpg (169.56 KiB) Viewed 7927 times
OK it's looking like the MJ unit is the problem. If I disconnect it (i.e. EDIS definitely operating in limp-home mode) then the engine idles and revs far smoother. I checked/traced all the wiring and could not find any evidence of shorted, or broken wires, or bad connections. So gut feel is telling me I need to replace the MJ unit
PROBLEM SOLVED
So I was about click the 'Buy' button an order a replacement MJ, but decided to hook the laptop up one last time to see if I could find the problem. I'm glad I did! ...
Turns out the Advance Correction data had been loaded with random garbage! Unfortunately I forgot to take a screen capture (pic below is what it should typically look like if good), but what I saw was that the correction values were large randoms such as -220, +44, -62, etc, plus the peak hold value was something up in the 37000 range. How that occurred I don't know (I've never touched that data in the past). Returning everything to zeros (i.e. disabling the advance correction) and everything is working OK again
I do have two observations though:
Cheers,
Colin.
- - The Advance Correction is not part of the saved map... and those values won't be wiped/overwritten if you load in a new map (or certainly not on my v3 hardware using rev v3.3.2 firmware and configurator)
- - Just before this problem happened I got an error message from the configurator... something along the lines of "Configurator not compatible with this rev of MJ firmware". I closed down, reconnected and didn't see it again. I'm wondering if there had been a bad comms session when opening the configurator s/w and the MJ hardware interpreted it as 'go change the Advance Correction values'???
Cheers,
Colin.
- Example of good data set (from operation manual)
- Mj_advance_correction.jpg (59.78 KiB) Viewed 7912 times
