Megasquirt 3 Pro CAN data preset issue
Posted: Tue Apr 13, 2021 7:00 pm
by MX-5RACER
I was able to get the CAN data working between the MS and RaceCapture, but I noticed that the numbers coming in for the AFR are actually the AFR Target, not the AFR data from the Megasquirt. I noticed the numbers on the RaceCapture for AFR did not match the one shown on the gauge and then verified that the MS matched the gauge. I was able to change the AFR Target table and saw the RaceCapture numbers change to match what I input into the MS table.
The settings according to DIY Autotune are as follows:
11 bit broadcasting
ID 1514 with an offset of 1 for the measured AFR
ID 1514 with an offset of 0 for the target
I cannot confirm what the settings are in the RaceCapture unit until I get back to the racecar.
Re: Megasquirt 3 Pro CAN data preset issue
Posted: Wed Apr 14, 2021 8:54 pm
by MX-5RACER
The preset in the RaceCapture unit is 1521 offset 4, but when looking at the data, the value matches the AFR1 Target table, not the actual AFR.
Posted: Mon Apr 19, 2021 4:14 pm
by MX-5RACER
No one else has this issue? Could there be a setting in the MS that is not correct?
Posted: Tue Apr 27, 2021 5:11 pm
by MX-5RACER
Just to round out the thread, I found these settings work for AFR with an MS3 Pro PNP:
CAN ID: 1523
Offset: 4
Length: 2
/10*1+0
Posted: Wed Sep 15, 2021 11:44 pm
Thanks. Looks like that is reflected in the latest CAN mapping for MS.
