More than four analogX on a single CAN bus
Q&A for AnalogX Analog to CAN interface. <a href="https://wiki.autosportlabs.com/AnalogX">Installation and Operation Guide</a>
jsa
Post by jsa »
Looking at the wiki I see the base address and offset configuration that allows 4 analogX modules on a single CAN bus.
Skimming through code on github I see
 // CANFilter shiftx2_can_filter = &#123;1, 0, 1, 0, 0x000E3700, 0x1FFFFF00&#125;; // g_can_base_address, ANALOGX_CAN_FILTER_MASK
offset |= palReadPad&#40;GPIOA, ADR1_ADDRESS_PORT&#41; == PAL_HIGH ? 0x01 &#58; 0x00;
offset |= palReadPad&#40;GPIOA, ADR2_ADDRESS_PORT&#41; == PAL_HIGH ? 0x02 &#58; 0x00;
Are there limitations that would prevent loading a revised firmware to analogX, with different base address or offset, values so that more than 4 modules could be on the same CAN bus?
Cheers
John
With updated firmware, you can have it listen on any CAN base ID as needed. No limitations.
jsa
Post by jsa »
Thanks Brentp. One step closer to purchasing more than 4.
What tools are needed to compile the revised firmware and load it to analogx?
Cheers
John
We have updated the documentation here, which will be sufficient for a knowledgeable engineer to program and update the firmware.
https://github.com/autosportlabs/AnalogX
If you are looking for a quantity OEM-style purchase, we can be contracted for these services. Just email [email protected] and we can help out.
Thank you,
