Megajolt Android tuning app
Note, you will need to ensure the bluetooth module's baud rate is set to 38,400. this might've been mentioned earlier in the thread..
-Brent
jestes
Post by jestes »
Good point Brent. I don't think that part was mentioned earlier in the thread. I talked about the hardware and the Android application, but not configuring the module itself.
capri_turbo
Post by capri_turbo »
I'll try that if I can ever get a bluetooth connection to talk to it. Trying a terminal emulator on the phone later.
capri_turbo
Quick question regarding changing the baud rate. I can't do it over the bluetooth connection as it needs to be in AT mode, so can I do it through the megajolt serial port if I pop the mcu out for safety?
Yes, that would work in theory. Keep us posted!
capri_turbo
Some good news. Using the MJLJ hardware with the MCU removed I can talk to the Bluetooth module via the serial port on the MJLJ. I get OK when I type AT and have been able to change the baud to 38400 using the AT+BAUD6 command and get the response OK38400. I have then gone back in using PuTTy at 38400 to check comms and AT returns OK so it must all be wired correctly.
I have powered down the module, put the MCU back in the jolt and have paired the phone again, connected the app and no data. Have I missed something?
Col
jestes
Post by jestes »
In the app, did you go to the Comms Settings menu and select the blue tooth pairing to use? I think the app will warn you if you don't but that is the only think I can think of that might be wrong. When do you get the error, when you click Connect?
capri_turbo
Here's what I've done so far.
Nice neat connector carrying 5V, Gnd, Tx and Rx all hard wired inside the MjLj:
HC-06 Bluetooth module wired into a small project box:
Fitted up and looking very neat:
Test bench wiring looms (currently using the MjLj hardware to gain access to the BT modules serial port):
Sadly still no comms to the phone app :( but it looks the part...
capri_turbo
Selected and paired to the module. App connects and modules LED stops blinking and stays solid.
Gauges all sat at "0" permanently. If I disconnect the app it says connection lost for about 5 minutes and I usually have to restart the phone to get rid of it, however it will reconnect quite happily but with no comms.
jestes
Post by jestes »
What version of the hardware and firmware are you using? It has only been tested with the latest.
Ah. V3 controller requires 9600 baud. Which is weird because that's the default baud rate of those BT modules. Maybe check if RX / TX needs to be swapped?
capri_turbo
V3 hardware with 3.3.1 firmware.
Col
capri_turbo
Tried swapping Rx and Tx with the baud as received which was 9600, same result. I'll have to swap the baud back to 9600 then :oops:
jestes
Post by jestes »
Is the comms protocol the same for V3 and V4?
IIRC it is different in areas. It has been so long :)
