START DELAY TILL' SPEC RPM
o07wray
Post by o07wray »
My MJjr has only one issue,, it fires instantly.. kicking back against the starter... Even before the engine has made 1 full rev the coil has fired!!
My suggestion: A set number of rev's before MJjr fires or a fixed/adjustable min rpm before it fires..
I thought about installing a NC push button switch that I can push in and cut the power to the MJjr untill the engine s starter has it turning over good,,,then release the button to turn on the MJjr...
Anyone else done the switch thing?
Unfortunately, with the current design the EDIS module fires the plugs on its own; Megajolt merely controls ignition advance. You'd be able to disable the coil using the button you described, however.
