Megajolt and KS3 PHORMULA KNOCK SENSOR
Posted: Sat Apr 30, 2022 11:14 am
by damunk
"The Phormula KS-4 Knock Monitoring Tool contains all the advanced features of the Phormula KS-3 plus:
0-5v Analogue Data Out
The KS-4 contains a true 0-5v analogue data output. Data output rates are configurable at up to a blistering 100 samples per second and fully compatible with all Data Logging Software, Engine Dyno’s, Rolling Roads and ECU’s. The 0-5v output can be integrated with an ECU to provide closed loop knock control.
Phormula Knock Datalogged"
I assume from here that this knock sensor can be trigged up to the 0.5V aux connector on the megajolt lite jnr and monitor knock against RPM graph?
I am looking to upgrade from my KS3 to KS4
Re: Megajolt and KS3 PHORMULA KNOCK SENSOR
Posted: Wed May 11, 2022 1:33 am
Yes, the auxiliary input could be used to modify the ignition advance - see the operation guide in the wiki for details on how that works.
You can emulate the knock sensor by manipulating the input using a variable voltage (potentiometer) and observe how the ignition advance is modified on the fly.
Posted: Sun May 15, 2022 8:46 pm
by damunk
Can't I just use that input to plot the knock readings on the GRAPH along the RPM line to see how they compare so that I can learn from it.
I don't want it to change the advance timings.
Posted: Tue May 24, 2022 2:33 am
You can with the aux input; simply leave the +/- adjustment at 0, which means "no change".
