1900cc honda motor...SOHC
Post 1900cc honda motor...SOHC
Engine Mfg: Honda
Engine Code: ET2
Cylinders: 4
Displacement (cc): 1900cc
Rev Limit: 7.5k
TPS or MAP: MAP
Boosted or Normally Aspirated: NA
If Boosted- max Pressure (KPa): (at high altitude, highest KPa reads at 86kpa when the car is off
Modifications: Dual Weber 45DCOE, 285i/e w/12mm lift, 11.5:1 compression 4-1 Header with 2.25 collector. No Head mods
Chassis: AB1 (1986 Honda Prelude)
Notes: At high altitude (5300ft-10000ft above sea level)
well, here is the map i'm running right now, and its kicking ass, probably could use more advance up top, but here it is anyway!
A20-DCOE-CB-07302011.mjlj
 Description:
A20 ITB ideal map adjusted for Altitude
Download
 Filename:  A20-DCOE-CB-07302011.mjlj
 Filesize:  786 Bytes
 Downloaded:  894 Time(s)
hondalude86 do you have a diagram on how you wired the mj into the oem honda wiring?
i am doing an f23a sohc project and was wondering if you could help me with the setup...
thanks in advance
We build CORRECTLY for COMPETITION;
NEVER for CONVENIENCE or CONVERSATION...
