After playing around a lot in the arduino community I have come across this little piece of kit.
http://www.arduino.cc/en/Main/MiniUSB
I am pretty sure this would ease a lot of those suffering with issues with there usb to serial adaptors. The only issue is that it would not be easy to incorporate this into a neat package.
It is all open source and there is quite a bit of documentation and support for it and is pretty successful with most PC's/laptops.
The only package I can think of is removing the pins, soldering 3 wires into where the pins (gnd, tx and rx) were located and then covering it all in some large heatshrink. Then this could be permanently located in the vehicle if the megajolt is hidden (bit like an obd port) or make up part of the communications lead.
An extra usb lead will need to be obtained. This looks like an old printer usb lead like this
http://www.cabling4less.co.uk/category.php?cat_id=152&gclid=CPq-57HDi60CFUVTfAodmR4rlw
Oh and it works well with windows 7
Anyone have any thoughts on this??
