Rover K series 1400 TPS on 33mm Bike carbs
Post Rover K series 1400 TPS on 33mm Bike carbs
As title
Aggressive map, used with MG TF cams and super unleaded. TPS is calibrated to suit unit fitted to bike carbs (Yamaha FZS 600)
Mini14K16.3.mjlj
 Description:
Download
 Filename:  Mini14K16.3.mjlj
 Filesize:  811 Bytes
 Downloaded:  416 Time(s)
Same set up as above but a tamer map used for daily driving and normal unleaded.
Mini14K16.4.mjlj
 Description:
Download
 Filename:  Mini14K16.4.mjlj
 Filesize:  811 Bytes
 Downloaded:  398 Time(s)
Why have you lower timing at high load / low rpm? Is there any reasons behind it?
Other question, you only ramp up timing at low load / high rpm with 1 or 2 degrees. Can't you add some more? I'm expecting to go from 32 at WOT to maybe 40-45 at low load.
I'm asking those question since I'll have to make also my own TPS map Wink
Mathieu
To avoid pre-ignition basically.
At small throttle openings, the actual compression ratio is low, due the throttle starving the engine. At such low compression, you need more advance to get good economy.
The wider the throttle, the more true compression goes up, bigger risk of pre-ignition.
not sure, we're talking about the same area on the map. I understand perfectly the need for more timing at low load ut not for high load at idle.
I've circled the area of concern to make things clearer. Is there any reason to do so? This is what I'm wondering Wink
 Description:
 Filesize:  59.61 KB
 Viewed:  5665 Time(s)
Mathieu
