Saab Sonett III on MAP-version
Post Saab Sonett III on MAP-version
Car: 1973 Saab Sonett III
Engine: Ford V4 Cologne version, 1.5 litres, NA
Mods: Weber 32/36 DGV 5A carb with K&N airfilter, twin 2' Highgate exhaust with absorption mufflers
No temperature compensation programmed, will be tried once temp sensor is hooked up.
15052013.mjlj
 Description:
Download
 Filename:  15052013.mjlj
 Filesize:  805 Bytes
 Downloaded:  377 Time(s)
Updated map. The 600rpm was not necessary, so I omitted this and added a 5500rpm range.
Alex
24012014.2.mjlj
 Description:
Download
 Filename:  24012014.2.mjlj
 Filesize:  816 Bytes
 Downloaded:  292 Time(s)
