Telemetry not connecting
Post Telemetry not connecting
Hello tech gurus,
I'm trying to get live telemetry working. I installed the sim card, set the APN and entered the devic id correctly. The LED blinks at a rate of about every 1 second and I get no data on RC live
There is 2 things I notice,
1- the sim card eject button does not spring the holder out, it does lock it in the RCP, but there is no spring feeling as the SD card does.
2- the telemetry LED is blinking at the same rate with or without the SIM card inserted.
I have a RCP Mk2. I use Bell as a carrier since I'm in canada.
By the way, the SIM is a 4G LTE, I don't know if RCP can use that type of SIM
Issue solved. I was using a SIM from a carrier that use CDMA network. When using a GSM network it works. Rogers and Fido are GSM for any interested Canadian RCP users.
Correct, RCP can only use GSM providers. Glad you got it working!
Ryan Doherty
Autosports Labs
