I had a chance to get these working today. There is one problem though. My sensors are setup for 16 channels each. I had to trim the script in the link above quite a bit because I was getting an out of memory error from lua. Even with trimming I was only able to get the front two sensors working. I can setup the sensors to use 8 channels but then I won't be able to do anything else with lua. Is there something I am missing here? I'd hate to think I can't use the ShiftX and Zeitronix scripts I have too. Here is the script I have working.
Code:
--This example is configured for IzzeRacing CAN-bus TireTemp-Sensors
--by
www.race-electronic.com
setTickRate(30)
BDF1Id = addChannel("BDF1", 10, 0, -20, 950, 'degC')
BDF2Id = addChannel("BDF2", 10, 0, -20, 950, 'degC')
BDF3Id = addChannel("BDF3", 10, 0, -20, 950, 'degC')
BDF4Id = addChannel("BDF4", 10, 0, -20, 950, 'degC')
BDF5Id = addChannel("BDF5", 10, 0, -20, 950, 'degC')
BDF6Id = addChannel("BDF6", 10, 0, -20, 950, 'degC')
BDF7Id = addChannel("BDF7", 10, 0, -20, 950, 'degC')
BDF8Id = addChannel("BDF8", 10, 0, -20, 950, 'degC')
BDF9Id = addChannel("BDF9", 10, 0, -20, 950, 'degC')
BDF10Id = addChannel("BDF10", 10, 0, -20, 950, 'degC')
BDF11Id = addChannel("BDF11", 10, 0, -20, 950, 'degC')
BDF12Id = addChannel("BDF12", 10, 0, -20, 950, 'degC')
BDF13Id = addChannel("BDF13", 10, 0, -20, 950, 'degC')
BDF14Id = addChannel("BDF14", 10, 0, -20, 950, 'degC')
BDF15Id = addChannel("BDF15", 10, 0, -20, 950, 'degC')
BDF16Id = addChannel("BDF16", 10, 0, -20, 950, 'degC')
BPF1Id = addChannel("BPF1", 10, 0, -20, 950, 'degC')
BPF2Id = addChannel("BPF2", 10, 0, -20, 950, 'degC')
BPF3Id = addChannel("BPF3", 10, 0, -20, 950, 'degC')
BPF4Id = addChannel("BPF4", 10, 0, -20, 950, 'degC')
BPF5Id = addChannel("BPF5", 10, 0, -20, 950, 'degC')
BPF6Id = addChannel("BPF6", 10, 0, -20, 950, 'degC')
BPF7Id = addChannel("BPF7", 10, 0, -20, 950, 'degC')
BPF8Id = addChannel("BPF8", 10, 0, -20, 950, 'degC')
BPF9Id = addChannel("BPF9", 10, 0, -20, 950, 'degC')
BPF10Id = addChannel("BPF10", 10, 0, -20, 950, 'degC')
BPF11Id = addChannel("BPF11", 10, 0, -20, 950, 'degC')
BPF12Id = addChannel("BPF12", 10, 0, -20, 950, 'degC')
BPF13Id = addChannel("BPF13", 10, 0, -20, 950, 'degC')
BPF14Id = addChannel("BPF14", 10, 0, -20, 950, 'degC')
BPF15Id = addChannel("BPF15", 10, 0, -20, 950, 'degC')
BPF16Id = addChannel("BPF16", 10, 0, -20, 950, 'degC')
CAN_map = {
[1220] = function(data) map_chan(BDF1Id, data, 0, 2, 0.1, -100)
map_chan(BDF2Id, data, 2, 2, 0.1, -100)
map_chan(BDF3Id, data, 4, 2, 0.1, -100)
map_chan(BDF4Id, data, 6, 2, 0.1, -100) end,
[1221] = function(data) map_chan(BDF5Id, data, 0, 2, 0.1, -100)
map_chan(BDF6Id, data, 2, 2, 0.1, -100)
map_chan(BDF7Id, data, 4, 2, 0.1, -100)
map_chan(BDF8Id, data, 6, 2, 0.1, -100) end,
[1222] = function(data) map_chan(BDF9Id, data, 0, 2, 0.1, -100)
map_chan(BDF10Id, data, 2, 2, 0.1, -100)
map_chan(BDF11Id, data, 4, 2, 0.1, -100)
map_chan(BDF12Id, data, 6, 2, 0.1, -100) end,
[1223] = function(data) map_chan(BDF13Id, data, 0, 2, 0.1, -100)
map_chan(BDF14Id, data, 2, 2, 0.1, -100)
map_chan(BDF15Id, data, 4, 2, 0.1, -100)
map_chan(BDF16Id, data, 6, 2, 0.1, -100) end,
[1225] = function(data) map_chan(BPF1Id, data, 0, 2, 0.1, -100)
map_chan(BPF2Id, data, 2, 2, 0.1, -100)
map_chan(BPF3Id, data, 4, 2, 0.1, -100)
map_chan(BPF4Id, data, 6, 2, 0.1, -100) end,
[1226] = function(data) map_chan(BPF5Id, data, 0, 2, 0.1, -100)
map_chan(BPF6Id, data, 2, 2, 0.1, -100)
map_chan(BPF7Id, data, 4, 2, 0.1, -100)
map_chan(BPF8Id, data, 6, 2, 0.1, -100) end,
[1227] = function(data) map_chan(BPF9Id, data, 0, 2, 0.1, -100)
map_chan(BPF10Id, data, 2, 2, 0.1, -100)
map_chan(BPF11Id, data, 4, 2, 0.1, -100)
map_chan(BPF12Id, data, 6, 2, 0.1, -100) end,
[1228] = function(data) map_chan(BPF13Id, data, 0, 2, 0.1, -100)
map_chan(BPF14Id, data, 2, 2, 0.1, -100)
map_chan(BPF15Id, data, 4, 2, 0.1, -100)
map_chan(BPF16Id, data, 6, 2, 0.1, -100) end,
function onTick()
processCAN(0)
end
function processCAN(chan)
repeat
if id ~= nil then
local map = CAN_map[id]
if map ~= nil then
map(data)
end
end
until id == nil
end
function map_chan_be(cid, data, offset, len, mult, add, filter)
offset = offset + 1
local value = 0
while len > 0 do
offset = offset + 1
len = len - 1
end
local cv = (value * mult) + add
setChannel(cid, cv)
end
map_chan = map_chan_be
initCAN(0, 1000000)
