I cannot open any log files as I get "Duplicate Column Name" when I try to open file. The attached file says there is a duplicate "POWER" variable. If I delete this, the problem just moves to a different variable.
At one point, I was using spaces and underscores in my variable names and some variable names were similar. I have since removed them. I feel that the problem may be related to "ghosts" of the old variables being loaded.
- rc_1.log
- (17.81 KiB) Downloaded 222 times
Okay, renamed some variable names so I no longer get the "Duplicatate Column Name" error. However, nothing shows up on the screen if I try to bring up a chart. I have attached a log file with data from a garage session, so there are no laps, but this should be no different than a dyno run.
- rc_8.log
- (118.07 KiB) Downloaded 225 times
We're working on a 1.9.2 release; we have a very alpha pre release here you can try. This is the windows build, assuming you're testing on that:
http://dropcanvas.com/2sp1j
This link will expire in about 15 days, but we should have the official release out before then.
