Heading via lua
Post Heading via lua
anyone worked out heading via lua?
not sure it's the best place to do it, due to jitter you would have to average out a few readings to calculate it reasonably
came accross this post when looking to see if this bridge had been crossed..
I've created a function that will give heading angle in degrees.I haven't tested this yet but in theory it should work if Lua is fully implemented.
I got the function from:
https://www.igismap.com/formula-to-find-bearing-or-heading-angle-between-two-points-latitude-longitude/
Code:
function headingcalc(lat2,lon2,lat1,lon1)
  rlat1 = math.rad(lat1)
  rlon1 = math.rad(lon1)
  rlat2 = math.rad(lat2)
  rlon2 = math.rad(lon2)
  dlon = rlon2-rlon1
  x = math.cos(rlat2) * math.sin(dlon)
  y = math.cos(rlat1) * math.sin (rlat2) - math.sin(rlat1) * math.cos(rlat2) * math.cos(dlon)
  rhead = math.atan2(x,y)
  return math.deg(rhead)
end
a lot of math functions to do, not sure how computationally expensive it will be. i'd operate it at a much lower tick rate than the GPS. maybe 10hz instead of 50?
