Finally got a couple of logs recorded but when attempting to open and view getting duplicate column "engine temp" warning can not open files.
I skimmed the forum, but didn't see an explanation I understood on where to find this column and how to fix it...
Computer idiot here...help please!
duplicate column help please
- Contact:
- Contact:
Sorry for the late reply here!
What version of the app are you running - is it the latest 1.11.0? We made some fixes in the app around this particular issue and would be good to know if the latest resolves your problem.
Latest version: http://podium.live/software
If you're on the latest, try doing this:
1) Go to your channel configuration for Engine temperature and change it from "Engine Temp" to "EngineTemp" - this should prevent future issues.
2) Load your datalog in Notepad (don't use word). Find on the first line of the file where it says "Engine Temp" and change this to "EngineTemp" - removing the space. Save your file.
3) try importing this file again.
We'll keep an eye on this thread - let us know how it goes!
- Contact:
- Contact:
OK, so I was NOT running the latest app, am running it now but still had the same result.
My channel for engine temp already had no space so I changed it to have a space just to try something, loaded a file on notepad and made the same change there, saved it and imported again onto the app. It will now open, but I don't appear to have any values?
If I didn't screw it up, there should be a screen shot of what I see when I open the log...
Thanks a bunch-Curt
Thanks a bunch-Curt
- Screenshot (1).png (69.27 KiB) Viewed 2930 times
- Contact:
Hi, thanks for the update. Your imported log file doesn't appear to have any values because it looks like distance was not recorded in that log file. Maybe you didn't have GPS lock, and/or you weren't moving?
Press the arrow ( ===> ) icon on the line chart. This will switch it to time based view - you should then see your data.
Any Progress on Duplicate Columns?
We're also seeing this issue. We' running a RaceCapture Pro MK3 and the RaceCapture App 1.11.0 on Windows 10.
I am able to view data by editing the .log file, and if I look at the file (by changing the suffix to .csv and reading it into Excel) there are no duplicate column names.
One thing that might be a factor - we swapped two analog input signals in the config. Had them swapped in the harness and changed the configs to fix it. We would have swapped them in the harness, but the MK3 connector is not user friendly like the MK1 connector was. It was one of the two signals that the app first complained about. (Ultimately it complained about several, all similar names: RFtravel, LFtravel, RRtravel, and LRtravel. I added an underbar to each and that pacified the app.
Hi Doug,
Actually, the last app release had fixes for certain cases on the duplicate column error, but it looks like we have some outstanding cases.
Could we get a copy of your app's datastore.sq3 and also a copy of the logfile you're trying to import? That way we'll be able to re-create the issue you're having.
You can find the location of the datastore by looking at the top of the application log. You can link your files here, or you can email the download link to [email protected].
Progress. Looks like the issue was case-sensitivity, or rather the lack of checking case.
Your datalog has the column: LRTravel; the database already has LRtravel. The RaceCapture app doesn't see this as a duplicate name, since it's considering case, but our underlying database technology is case insensitive. Our previous fix to the duplicate column name accounted for a different issue.
We should be able to compensate for this in the updated app.
