it wasn't darkweb, but "unsupported" is a better description. I chose the Waveshare 10.1 resistance touch LCD because I felt the 7" was to small for our type of cars. and I didn't want to have to use special gloves. I also liked that the pi attaches directly to it. it has the ads7846 chip and uses the hidinput.
do I need to do anything special with the rc.local file? does ether line need to be first?
sudo nano /etc/rc.local
ADD BEFORE EXIT0
python /home/pi/.off_button.py &
/opt/racecapture/boot_racecapture.sh pi
Raspberry Pi support - enables a hard-wired, dedicated dash
RPI on all versions?
Will running the app on RPI work with Racecapture Pro Mk1 as well?
Guys, I recorded a video to show how RCP app can be operated in Raspberry Pi using a wireless mini keyboard and touchpad combo. Check it out:
https://www.youtube.com/watch?v=b3tk3h51GNg
--Paulo
Which version is this?
Just asking because 1.11.0 doesn't seem to be responding to these (and I've had no success getting a visible cursor for the mouse), but wanted to know if I should be waiting a little longer...
brentp wrote: Worth mentioning, next app version due out in a couple of weeks we'll have more keyboard shortcuts:
'd' -> navigates to dashboard
's' -> navigates to setup
'a' -> navigates to analysis
'p' -> navigates to app preferences
't' -> navigates to status
ctrl-q -> exit the app
In modules section:mikesmith wrote:In which section? I've tried all of the obvious places, but I don't see "cursor = 1" mentioned in any of the relevant Kivy documentation (did you mean show_cursor?)psfp wrote:It was really simple (after I figured it out, of course )
I just added a "cursor = 1" row in Kivy's config.ini file
(to access this file you must type sudo nano /home/pi/.kivy/config.ini in command line)
--Paulo
