Default Ignition MAP
Post Default Ignition MAP
This is the MAP included by default with the MJLJ processor.
It is a 'safe' map that can work for boosted as well as normally aspirated engines.
FactoryDefaultMap.mjlj
 Description:
Download
 Filename:  FactoryDefaultMap.mjlj
 Filesize:  725 Bytes
 Downloaded:  4567 Time(s)
Brent,
I am re-building my carb setup engine which runs a tad rich at present and going from 1.4L to 1.6L + the new mild road camshafts.
My current map which was set on rolling road is on thread: https://forum.autosportlabs.com/viewtopic.php?t=5602
I need a safe map to:
1) run my cams in for 20 minutes stationary
2) run the new piston rings in for a few hundred miles before i take it to the rolling road.
Better to use the default map? I have used the default before on the 1.4 but that was only to get it to the rolling road.
The difference this time is I am building an engine that will need running in before I find it comfortable to take 100 miles to the rolling road.
