I've used the online template and standard assignments for all of the zones of the the tirex kit. only The first four zones are reporting a number, the remainder are showing up as zero.
Also, every time I power cycle the unit, everything shows up as zero, after I cycle the can bus termination button The first four zones will begin reading correctly, and it doesn't seem to matter if I leave it terminated or not, including different baud rates. The unit simply will not show any temperatures after a power cycle unless I change a setting.
Halp!
Tirex zones won't show up correctly
dmendez492
Jump to
- Autosport Labs
- ↳ General Discussion
- ↳ News and Announcements
- ↳ New Project Suggestions
- CAN Devices
- ↳ ShiftX2
- ↳ AnalogX
- RaceCapture App
- ↳ RaceCapture App Operation and General Q&A
- ↳ RaceCapture App Bug Reporting / Feature Requests
- CAN bus and OBDII integration
- ↳ CAN mapping discussion
- ↳ OBDII PIDs discussion
- RaceCapture/Pro | RaceCapture/Apex | PodiumConnect
- ↳ RaceCapture/Pro introductions
- ↳ RaceCapture/Pro General Q&A
- ↳ Sensors
- ↳ Hardware and Installation
- ↳ Lua Scripting
- ↳ Telemetry
- ↳ Bug Reporting
- ↳ Feature Requests
- RaceCapture/Track
- ↳ RaceCapture/Track Introductions
- ↳ RaceCapture/Track Operation
- ↳ RaceCapture/Track Installation
- ↳ RaceCapture/Track Bug Reporting / Feature Requests
- Megajolt/E and Megajolt Lite Jr. (MJLJ)
- ↳ Ignition Map Library
- ↳ Powered by Megajolt Gallery
- ↳ Assembly
- ↳ Installation
- ↳ Operation
- ↳ Q&A
- ↳ Future Upgrades
- ↳ Bug Reporting
- ↳ Fixes/Patches/Updates
- ↳ Hard Rev Limiter
