I've used the online template and standard assignments for all of the zones of the the tirex kit. only The first four zones are reporting a number, the remainder are showing up as zero.
Also, every time I power cycle the unit, everything shows up as zero, after I cycle the can bus termination button The first four zones will begin reading correctly, and it doesn't seem to matter if I leave it terminated or not, including different baud rates. The unit simply will not show any temperatures after a power cycle unless I change a setting.
Halp!
Tirex zones won't show up correctly
dmendez492
Re: Tirex zones won't show up correctly
Also, how does one change the sample rate of the sensors?
