Converting from MAP to TPS
Post Converting from MAP to TPS
I have a V3 board that currently works with MAP. I now have a set of bike carbs with a TPS attached, which may be the easiest option once I get them installed.
I should have no problem with adding the small number of extra components required for TPS, but I'd like to disconnect the MAP system with the minimum amount of disruption, in case I want to use it again later. Is there one component or link I could remove to isolate that part of the circuitry, so that it doesn't interfere with the rest?
cheers,
David
Removing R4 should do the trick.
Richard.
