Default cable to VR sensor from Ford not shielded !?
I bought a complete package from triggerwheel.com with sensors, coils, EDIS-units, harness etc.
Now that I'm installing it in the engine bay I notice that the cable that came with the VR-sensor (which is from a Ford) - it is not shielded.
I thought it would be.
Now, I concidere this solved, since where I assemble it with the harness to the EDIS-unit i cover the joint with a crimp-boot. And I have one that is shielding - and now I've covered the whole of the cable from the VR-sensor with it. And I'm simply joining this crimp-boot with the shielding that is in place on the harness from the EDIS-unit.
This should do it - shouldn't it?
And isn't it strange that this cable isn't shielded in the first place ?
I've just looked at two of my VR sensor cables - both OE Ford.
One is shielded, one isn't.
Maybe:
- Ford decided that shielding was needed in some cars' installations, but not others, depending on the routing of the cable
- early ones were not shielded and there were problems so later ones were
- early ones were shielded but the bean counters decided that no shield was cheaper
Without knowing exactly how the VR signal is handled inside the EDIS, it's difficult to say how susceptible it is to electrical noise. It is a low frequency ac signal where the only important thing is the "zero crossings" - it's feasible that some simple electrical filtering in the EDIS could make it fairly immune to interference - unlike the PIP and SAW signals which are digital in nature and more susceptible to interference, and hence run in shielded cable
Having said that, I wouldn't run the VR sensor cable (either type) directly across the plug leads!
What you've done is probably on the cautious side, but at least it means that you should be able to eliminate VR sensor cable noise pickup if you have any problems...
Maybe:
Ok, thanks.
I'll avoid the plugleads. I have the EDIS-unit and the coilpack just about smack up to each other. This means that the cable from the VR-sensor comes at one point at a distance of say 10-15cm of the plug leads. Do you think that will be a problem ?
I work in the Avionics industry, I used twin twisted shielded wire (red / blue wires braided shield) we use for audio in aircraft.
It is flame retardant / heat resistant and half the diameter of the Ford cable. Check your local aircraft parts store, in England Adams Aviation Biggin Hill should be able to help, or just give a aircraft maintenace company a call.
I also de-pinned the EDIS connectors and fitted the new wire directly, I hate terminal blocks!!
Simon
Simon
You soldered the edis connection directly ? Personally I'd prefer to have the EDIS unit securely fastened in the engine bay and still being able to remove the wiring.mwman wrote:I work in the Avionics industry, I used twin twisted shielded wire (red / blue wires braided shield) we use for audio in aircraft.
Simon
I use a flame and heat resistent cable too. It's for automotive use though.
I think I used the same for GPS signals on the glider I used to own. So the automotive cable came to use in aviation too.
Yes,mwman wrote:Hi Patriq,
No you misunderstood what I said, I have taken the pins out the EDIS plug, removed the old wire and re-used them.
I did not want to solder /sleeve the old wires, looks much better!
Simon
sorry - I misread you.
Yeah - that would like much cleaner.
just to emphasise a point touched on by simon, twisted pair cables are twisted specifically because the twist reduces the effect of EMI on the twisted wires. you will note that this is, for example, the world standard for telephone cabling. it is an alternative to foil and braid shielded cablel; easier to work with, and more flexible. not that i gave that a moments thought when i wired up my loom with shielded cable! using proper twisted pair cable may be a better alternative; i found the soldering the shield and earthing it a bit of a pain; i also note that if you use braid shielded cable, you have to be really careful that you dont let a single little strand of the braid touch the inner core, when joining to connectors, as that would short the signal to ground.
alexander.
alexander.
After reading (above) that the earthed sheath may not be necessary with twisted pair, I was wiring mine temporarily (using castle connectors) just to check the polarity of the VR connections, and I didn't bother earthing the sheath. After two hours of checking everything I could think of, and getting no spark at all, I finally earthed the sheath on the VR wire and BINGO - big fat sparks visible even in sunlight!
I say buy the sheathed stuff and use it
TwoSheds
TwoSheds
